Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Squeaky Shaker
Old May 14, 2008 | 07:50 PM
jmac72187's Avatar
jmac72187
corner carver
Default Squeaky Shaker
My shaker has been squeaking a lot lately and it is really starting to get annoying. Has anyone else has this problem? How did you fix it?
Old May 14, 2008 | 09:14 PM
Sace's Avatar
Sace
Default RE: Squeaky Shaker
i think alot of guys have this.. i dont even notice mine .. i only notice mine when im standing outside the car when its idling. cant hear it any other time. is urs worse ? as for the soloution i havent heard of ne guys around here that got the problem try to fix it. id like to know tho
Old May 15, 2008 | 12:02 AM
MACHJUAN's Avatar
MACHJUAN
have you raised your shaker with washers, that is the solution to that problem most of the time, if not you might want to replace the shaker plastic holder.
Old May 15, 2008 | 05:46 AM
jmac72187's Avatar
jmac72187
corner carver
ORIGINAL: MACHJUAN
No I haven't. How do I do that?
Old May 15, 2008 | 10:35 AM
MACHJUAN's Avatar
MACHJUAN
http://www.mach1registry.com/shaker/
Old May 15, 2008 | 10:37 AM
jmac72187's Avatar
jmac72187
corner carver
This will stop the squeaking?
Old May 15, 2008 | 10:43 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
if you put spacers in it should.i mean things squeek b/c they get loose, so if you make it tight again it should stop squeeking
Old May 15, 2008 | 11:27 AM
jmac72187's Avatar
jmac72187
corner carver
ORIGINAL: USMCrebel
haha I still don't understand where the spacer go. Do they go on the ball joints or something?
Old May 15, 2008 | 11:30 AM
MACHJUAN's Avatar
MACHJUAN
you notice were the wrench is at? remove it like pictured place the spacers on after the **** is removed reinstall **** and your done.
Old May 15, 2008 | 11:31 AM
USMCrebel's Avatar
USMCrebel
you know in the how to raise your shaker tutorial on M1R (the link) put them on the bolt to raise and tighten that junk down....if i coudl se pics i could edit them to show where to put them.
