Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Squeaky Shaker
Old May 15, 2008 | 11:34 AM
jmac72187's Avatar
jmac72187
corner carver
Default RE: Squeaky Shaker
I feel like an idiot, but I am still confused.
I see black knbs that the shaker fits onto, but I don't understand where the spacers go. Could I just put grease on the ball joints?
Old May 15, 2008 | 11:37 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
yeah i would try that first, im at work, so i cant edit pics
Old May 15, 2008 | 11:47 AM
MACHJUAN's Avatar
MACHJUAN
just unbolt the ***** with a 15MM wrench, then place the spacers inbetween the **** and the place where it bolts into.
Old May 15, 2008 | 11:49 AM
jmac72187's Avatar
jmac72187
corner carver
ORIGINAL: MACHJUAN
Oh ok. I was thinking that it was the Ball joint things that were making the sqeuaking sounds.
Old May 15, 2008 | 11:53 AM
MACHJUAN's Avatar
MACHJUAN
cool, nice freemod(raising it a bit)
Old May 16, 2008 | 04:32 AM
Mustang9668's Avatar
Mustang9668
I had the same problem but when I put on my intake spacer from Roy is stopped it. Gained some power at the same time.
There was a TSB on the rattle and there is another fix for it. Check it out here: http://www.mach1registry.org/forums/...=shaker+rattle
If you are a member on the registry then you have probably heard about Roy's spacers.
Old May 16, 2008 | 08:15 AM
USMCrebel's Avatar
USMCrebel
i preach about them all the time
JoshyGT
Sep 19, 2017 08:52 PM
degner122
Sep 16, 2015 07:09 AM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
Shifty Magoo
Aug 25, 2015 03:08 PM
