Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Just ordered my intake spacer
Old Jul 28, 2008 | 12:48 PM
jmac72187's Avatar
jmac72187
corner carver
Default Just ordered my intake spacer
I just ordered my intake spacer from Roy about 5 minutes ago.
Anyone have any tips on the install? I have heard about problems with the EGR but Machwon told me that it wouldn't be too hard with two people. What exactly is the EGR issue? I don't have any idea what the EGR looks like or how it works.
I might be ordering a JLT RAI also this week to help out. I am still using my stock paper air filter and stock intake.
Old Jul 29, 2008 | 08:09 AM
Machwon's Avatar
Machwon
Default RE: Just ordered my intake spacer
Ah you'll be fine man! If no one will help re-align the EGR (its going to be sitting about 1/3" or however thick your spacer is higher after install), a good screwdriver pry should do it for you- you just have to get the 2 10mm bolts lined back up. Just make sure you dont cross thread either of them- I have heard of this before and it can end up being a PITA. Other than that the install is very strait forward, be methodical about it and keep good track of where what bolts / washers / nuts go and you'll be fine!
Old Jul 29, 2008 | 08:24 AM
DesertMach's Avatar
DesertMach
The install is pretty straight forward, I installed my PHP spacer (pretty much the same thing as the Roy intake spacer) in about an hour by myself, the EGR gave me no problems at all.
There was a write up for the install with pictures over at the M1R if you need it.
04stangman
Sep 17, 2015 01:45 PM
J.casone400
Sep 12, 2015 10:01 PM
Sep 10, 2015 08:39 PM
Webster454
Sep 7, 2015 04:59 AM
