Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
supercharger ?
Old Aug 1, 2008 | 07:35 AM
tws1098's Avatar
tws1098
Default RE: supercharger ?
ORIGINAL: Furinox
ORIGINAL: tws1098
Sorry guys I should have clarified what I meant. It is the full take off from the cobra, I was basically wondering how much cost was involved in fitting it up to the mach motor (keeping the shaker kit and all). but the s/c, heat exchanger, fuel injectors, mass air, pulley, and maybe the fuel pump were all included in the used one i looked at. The unit had 11,000 miles on it before removal for an upgrade.
thats not even close to all the stuff you need.
i didnt say it was, you could enlighten me on what i need rather than state the obvious
Old Aug 1, 2008 | 08:04 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
here is the list with part numbers as well..it's kinda daunting looking at this list
(6312) Crank pulley /Harmonic Balancer
(6312B) Supercharger Crank drive pulley
(8678A) Pulley w/mount Replaces stk. alt. Pulley on 99-01 Cobra’s and 03/04 Mach 1’s
(6B209B) Pulley bridge assembly for S.C. (bracket, 2 idlers, tensioner)
(8678B) Idler pulley,timing cover pass. side
pulley, timing cover drivers side
(6D080) Timing cover
(10A313) Upper alternator bracket
(10153) Lower alternator bracket
(10346) Alternator
1U2Z-14S411-TA Electrical connector (alt. to harmness )
(6B209A) Tensioner on timing cover
(8260) Radiator hose
(8A593) Radiator hose
(8K576) Radiator hose
(8548) Water cross over pipe
(6881) Cobra oil cooler adapter
(6A642) Cobra Oil cooler
(9002) Cobra fuel tank
(9H307) Cobra fuel pump
(6F066) Eaton supercharger
(9424) Lower intake
(6K775) Garrett factory intercooler
3U2Z-14S411-SSA IAT2 sensor connector
(9H308A) Intercooler hard lines that hug the block
(9N491A) Intercooler hard lines that come from the h/e
(9L443A) Intercooler line that goes from the i/c adapter to i/c res.
(9L443B) Intercooler line that goes from the i/c adapter to the hard lines that hug the block
(9L443C) Intercooler line that goes from the hard line against the block to i/c pump
(9L443D) Intercooler line that goes from hard line to hard line
(9L443E) Intercooler line that goes from hard line from h/e to i/c pump
(9L443F) Intercooler line that goes from hard line and connects to h/e
(9L443G) Intercooler line that goes from hard line and connects to h/e
(8501) Ford / Bosche water pump for intercooler
(8N500) Intercooler pump bracket
(8K226) Factory heat exchanger
(8A193) Heat exchanger mounting bracket
(8C386) 2each bracket clamps for h/e
(9N491B) Lower manifold to intercooler water adapter
(9A589) Plenum
DELETED TB SAME AS MACH
(9B659) Intake tube from maf to t/b.
(9F715) IAC valve
(9F593) Injectors
(6F089) Boost bypass actuator
(9A825) Cruise control cable
(9A758) Throttle cable
(9728) Throttle and cruise control cable mounting bracket
(12B579) MAF
(9D475) EGR valve
(9D477) EGR tube
(6C324) PCV tubing
(9F479) Sensor on the back of the S/C
(9J432) Bracket for vacuum stuff on left side of the S/C
(9H465) Vacuum stuff
(9J459) Vacuum stuff
(9J460) Vacuum stuff
(9E498) Hose's or tube cluster of connectors for the vacuum parts above
(9F670) IAC gasket
(6020) Timing cover gasket LH side
(6020) Timing cover gasket middle
(6020) Timing cover gasket RH side
(9H486) Intercooler to S.C. gasket
(9L437) Plenum to S/C gasket
(9D476) EGR gasket
ADDED:
Power steering resevoir bracket.
I/C resivoir tank
i/c pigtail
S/C 8 rib belt
inner acc. belt.
Old Aug 1, 2008 | 11:09 AM
tws1098's Avatar
tws1098
haha thats alright man, thanks for the list, I knew it would be nice and long. Still sounds like something I want to do if possible lol.
Old Aug 1, 2008 | 11:12 AM
USMCrebel's Avatar
USMCrebel
if its what you wanna do go for it!
but for ease procharger makes the P1sc1 and the P1sc2 and the D1sc that would suite you perfectly as well
GimpyHSHS
19
Dec 19, 2023 01:12 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
col2560
Sep 25, 2015 08:59 PM
