Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Need some advice
Old Aug 27, 2008 | 06:20 PM
03machstang's Avatar
03machstang
Default Need some advice
What is your guys opinion on cutting the springs to lower your car?
Old Aug 27, 2008 | 09:18 PM
armymike63b's Avatar
armymike63b
i wouldnt man just buy the right springs for the height you want
Old Aug 28, 2008 | 01:09 PM
03MachMe's Avatar
03MachMe
you can cut them all you want thats what i did and saved about 200 bucks. it doesnt hurt them at all they are a liniar rate spring. that means that cutting them doesnt change the stiffness or quality of the ride just changes the size of the spring. i recomend cutting about 3/4 of a coil unless you want to get some CC plates then a full coil and will look like sex. the problem with cutting springs is when ppl cut the progressive rate springs thats when you see cars that bounce up and down when driving. the stock mach springs are fine to cut do it and save yourself the 200 and buy a diffrent mod so you get 2 mods instead of 1
Old Aug 28, 2008 | 03:21 PM
Furinox's Avatar
Furinox
be sure to use a cutoff wheel and not let it get hot. heat will change the spring rate.
Old Aug 28, 2008 | 07:46 PM
1HottMach's Avatar
1HottMach
No worries man! I have H & R springs but I have cut springs in the past and had no problems.. She'll look tight afterwards!
Omgitsa88Stang
Oct 5, 2015 07:33 AM
Shadow7874
Sep 24, 2015 09:06 PM
2k232
Sep 16, 2015 10:28 AM
EASTIDEE123
Sep 15, 2015 11:08 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
