Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
block help
Old Sep 3, 2008 | 06:34 PM
FELEN's Avatar
FELEN
Default block help
im looking into buying the aluminator block but not sure what else i would have to buy in order to install it.... and i also noticed that there are 2 blocks the n/a block and the supercharger block....
if i want to supercharge my mach down the line will the n/a block require me to buy other stuff down the line or will i be fine???
n e help would be greatly appreciated thanx...
Old Sep 3, 2008 | 09:06 PM
myslow2002gt's Avatar
myslow2002gt
You would be better off building a shortblock off your current block. The aluminators are ok, but for the price you can build a MUCH better shortblock.
The difference is compression, if you plan on boost, stay in the 9.5:1 range with a 4v.
Old Sep 9, 2008 | 10:41 AM
StangRyder's Avatar
StangRyder
In my case I have a 99 GT auto tranny and would like to upgrade to a 4V engine. The Aluminator long block offered by FRPP seems like a very cost effective alternative to me.
In my case what is needed? I also plan on changing the tranny to a T-56 but on the long term. I'd like to keep my tranny and start with the engine.
Any suggestions?
Old Sep 9, 2008 | 12:46 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
Felen, what power level are you looking at? you will crack the aluminator block is you put normal 4v mounting bolts in it...the threads are deeper.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mustangheaven
Jan 3, 2016 11:20 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
mustangheaven
Sep 29, 2015 11:00 AM
wraith777
Sep 28, 2015 10:49 AM
