Why should I port and polish?
Should I have my heads ported and polished? I have about 100k miles on the Mach, and I'm assuming they haven't been P&Ped before.
Will I really feel a difference and what would the HP/Torque increases be?
Thanks!
Thanks!
Are you planning on having any additional work done like new cams or larger valves? May be a good time to just do it all.
Even if you do nothing else but P&P you will probably see a solid 10% gain in power at the flywheel because you have a 4 valve. Those typcially see a bigger improvement with higher flowing heads than a 2 or 3 valve.
If you're going to be building a H/C motor, it's definitely in your best interest to forge your bottom end while it's apart. You can't utilize the higher revving capabilities of a radical set of cams if you're bottom end won't take the additional RPM. Personally, I would forge it with a nice piston/rod combo from MMR and do a small bore job on the block while it's getting cleaned up and get the appropriate pistons. Your crank is already forged, assuming you're a 5 speed. This way if you ever want to go F/I down the road or spray, you'll be in your safe limits.
For cams, you can't beat a custom set if you want the most usable power. Good off the shelf grinds are any of the stage 2 and 3 Comp and Crower cams. A good set of customs from say Modular Performance are going to run you about $1200. An off the shelf like the crowers will be around $900, depending on retailer.
Also, getting your intake ported by someone like Roy is going to open up your top end even more. With a big set of cams and heads, you'll see pretty good gains with a ported stocker.
