Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Affordable cams for a 4v...WTF!
Old Feb 12, 2009 | 12:47 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
i bet it makes a pretty good bump on the power
Old Feb 13, 2009 | 01:15 AM
I G Joe's Avatar
I G Joe
where can i find these cams! ive tried ebay and craigslist, nothing...
Old Feb 13, 2009 | 07:54 AM
USMCrebel's Avatar
USMCrebel
it just takes some looking and some waiting.
Old Feb 14, 2009 | 01:01 AM
I G Joe's Avatar
I G Joe
took a little bit of searching but i found some! now to degree them i will need some adjustable gears huh.
Old Feb 14, 2009 | 07:08 AM
livefast1's Avatar
livefast1
hey guys i just purchased a mach with a vortech s trim. i know blower cams would be optimal because of the lsa, but if these would still be a good upgrade in the future. all ive ever seen were adjustable cam gears for the main gear, does anybody make adjustable secondary gears? that would allow me to adjust the lsa on the cams making the cobra 98 cams work a little better.
Old Feb 14, 2009 | 05:25 PM
rob.d's Avatar
rob.d
What do you mean by adjusting the lsa? The lsa is ground into the cam and can not be adjusted. You can however adjusted centerline angle that the cam is installed at by advancing or retarding the cam.
Also their is more to blower cam then just lsa. Every part of the VE should be looked at when choosing blower cams. Just thought I would put that out their.
Old Feb 14, 2009 | 05:47 PM
livefast1's Avatar
livefast1
i thought lobe seperation was the amount of degrees difference between the intake and exhaust lobe hence why it determines over lap. so if you could adjust the intake and exhaust cam you should be able to adjust lsa? maybe im not remembering correctly.
Old Feb 14, 2009 | 07:52 PM
USMCrebel's Avatar
USMCrebel
if your gonna go blown i would look into custom as you will see a TON more of a gain than a stock ford cam
Old Feb 15, 2009 | 08:42 AM
livefast1's Avatar
livefast1
im blown as we speak (haha sorry had to), didn't know if it would be a cheap alternative.
Old Feb 15, 2009 | 09:30 AM
PCPRO's Avatar
PCPRO
Hey guys,
There is a set of 50k mile '98 Cobra cams for sale today, for $150 in the "cobra parts for sale forum" at svtperformance.com
