Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
IAC Valve Test
Old Jun 18, 2009 | 06:11 PM
fRankie03Mach1's Avatar
fRankie03Mach1
Post IAC Valve Test
Hey guys wats up? Having a little problem here with my 03 mach 1.
While coming to a stop RPM's stay about 1.2k - 1.3k then in a few seconds RPM decreases to the point car stalls out. I heard this could be my IAC valve. I cleaned it along with MAF sensor, but i heard about a test to check if the valve is working properly by disconnecting the 2 bolts and leaving the electrical connection on and put the key to the "on" position (without starting the engine), the IAC should move up or down, if it does its fine. Mine is moving down like not even a mm(you can hardly tell) and then goes right back to originally position.
I am replacing the valve anyway but i dont think its working properly or is it?
Old Jun 18, 2009 | 06:26 PM
Mustang3GT07's Avatar
Mustang3GT07
I had the same problem in my Mach1. Do you have a intake on their?
When I installed my K&N Intake I forgot to re-install the screen in the intake tube and it kept doing the same thing yours is. I put the screen back in and problem solved. If you don't have a intake disregard everything I just said lol.
Old Jun 18, 2009 | 06:35 PM
fRankie03Mach1
Ya i have the JLT Ram air intake. The screen is there, no holes in it. I even removed the screen and still does it, i put it back in there.
Thanks for the quick response.
Old Jun 18, 2009 | 06:40 PM
Mustang3GT07
Ok next solution. Their were a couple threads on this I believe over on Mach1registry.com and some people said this happens in the stock tune from the factory and that the computer needs to be re-flashed and car needs to be tuned. A couple guys over their went and got their car dyno tuned and problem was solved.
Old Jun 18, 2009 | 07:58 PM
03MachMe's Avatar
03MachMe
mine does it as well. i just keep it in gear till i slow down enough that the RPMs are around 1k or so then put the clutch in and that makes it to where it wont stall. but im sure a tune would help
Old Jun 18, 2009 | 08:08 PM
northbaseball22's Avatar
northbaseball22
i have JLT ram air w/o screen and im fine
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
GT350 S550 Tech
Sep 29, 2015 03:29 PM
