Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
automatic mach1
Old Sep 9, 2009 | 10:36 PM
  #21
grif62's Avatar
grif62
auto's ftw!
Old Sep 9, 2009 | 11:33 PM
  #22
justinschmidt1's Avatar
justinschmidt1
Originally Posted by USMCrebel
honestly if i had it to do over again...i would've gotten an auto mach throw 4.10's...x-pipe, drop in, intake spacer, ~4k stall, 96-98 cobra cams advanced 10*, Lt's, electric WP, and a 125 shot and ran 10's all day
hell yea
I dont know why people hate on the auto....
I know for a fact that a mach 1 with 4.30s, and a 4k stall would be dirty, even in stock form I bet.
Old Sep 10, 2009 | 01:22 PM
  #23
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
i've been debating whether or not to get another mach 1 and use it strictly for the track, or use my 1967 2.3t as a combo DD/strip queen.....<is getting closer to being done. pulling the motors this weekend, and getting the 67 set up for wiring (all 5 of them lol)...eventually i'll have a MS custom built with a holset HX35 @30psi running meth injection esslinger cam and maybe a boport head. BTW all that will be contained by a C5 ( a cooling improved C4)
Old Sep 10, 2009 | 08:23 PM
  #24
mrxr250rider's Avatar
mrxr250rider
ill miss the 5spd though. my old stang was auto and i love the stick so much more.
i have awhile to decide.
i want to either build my car,trade for the mach or sell/trade my car for a 96-98 cobra
Old Sep 10, 2009 | 10:08 PM
  #25
USMCrebel's Avatar
USMCrebel
i would build your car...with a 5.4 aussie intake mach 1 cpu ....yes there is a kit for this that WILL bolt directly into your car.
the setup ^ is good for lets say 385/385....IE cobra R setup.
Old Sep 10, 2009 | 10:13 PM
  #26
justinschmidt1
The problem with that is you cant compare a normal, slow *** stock auto mustang to say a mach one with 4.30s and a badass stall.
My car started as a 96 gt auto, slow and gay.
But add 250 hp, a 3800 stall, 373s, and a jmod, and the auto all of the sudden becomes god
Old Sep 10, 2009 | 10:31 PM
  #27
a_penquin's Avatar
a_penquin
how about you swap the 5spd from the GT to the Mach?
Old Sep 11, 2009 | 08:02 AM
  #28
grif62's Avatar
grif62
I agree with justinschmidt 1,
there can be some BA auto stangs out there, just need the right stuff.
Old Sep 11, 2009 | 08:31 AM
  #29
'00project's Avatar
'00project
The only problem with the auto mach is the cast rotating assembly. If you swap the auto to your gt you will need to get an auto computer for the gt. There is a little more going on in there to shift the electronic auto. If you have to have the 5 speed; I would spend the money to get the short block rebuilt with a stroker crank, trick flow heads (or at the least ported PI), and a trick flow track heat intake.
Old Sep 14, 2009 | 11:53 AM
  #30
USMCrebel's Avatar
USMCrebel
1st it's not a 5.0...our heads flow fine they use a version of them on the ford GT. The crank will be fine for any stock rpms or 6800 redline shifting.
