Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
fastest pass, again....suggestions?
Old Apr 3, 2010 | 11:46 PM
rygi23's Avatar
rygi23
Default fastest pass, again....suggestions?
5th trip to the track in a row I've beat my best time, but it's gettin down to the nitty gritty. With some subtle mods, practice launching and learning shiftpoints my best pass each trip have gone like this...13.11, 12.91, 12.60, 12.39, 12.38, 12.37. Any budget-minded mods y'all can think of that yields real-world results? Current mods in sig. Thx in advance.
Old Apr 4, 2010 | 03:19 AM
Fstanggt96's Avatar
Fstanggt96
Full length sub-frame connecters. Install your LT headers... lol. Short throw shifter.
Old Apr 4, 2010 | 10:35 AM
rygi23's Avatar
rygi23
Fine w/ stock sub-frames, straight-line performance is fine. Waiting for a deal on an install for LTs, or someone willing to let me use their lift, don't think their's much difference between LT/ catted X and o/r X. I have a triax shifter.
Old Apr 4, 2010 | 05:50 PM
watman02's Avatar
watman02
you could do some weight reduction ie. back seat, spare tire, jack pass seat. etc. or you can always spray your way faster. also i was wondering do you have upgraded axels?
Old Apr 4, 2010 | 08:02 PM
rygi23's Avatar
rygi23
Pass. seat/spare tire are taken out, guess I'll get a rear seat delete as I hate messing with the rear seat everytime I go to the track. No spray here, I want very low 12s/high 11s with bolt-ons. I get asked about the axles alot. They're stock, which are fine w/o clutch dumping.
Old Apr 4, 2010 | 10:41 PM
Stone629's Avatar
Stone629
Control arms should drop your ET some. Keeping the weight transfered to the rear is a big help too. Everytime that nose drops, it loses momentum and puts drag on the car trying to pick it back up. Getting some weight off the front is very helpful with this. Using an aftermarket lighter weight radiator mount, K-Member, front control arms, etc, is a good start. The Battery relocation helps too. I know your not a big fan of the aluminum DS, but its weight some off the drivetrain. I know these things aren't the most budget minded mods, but it gives you some mods to put on your wishlist that are proven without having to spend big money. Out of all the things I listed, I'd do the LCAs first. They work.
*If you do end up doing LCAs, keep a check on your torque boxes. The factory ones will eventually come apart with hard launches and require weld in boxes, very easy fix*
Old Apr 5, 2010 | 09:21 AM
Mach1man's Avatar
Mach1man
Those are some damn impressive runs for the mods you have! That 1.69 sixty foot is like your best buddy at the moment. What track are you running at, MIR?
Old Apr 6, 2010 | 12:51 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
intake spacer 3/8"
LCA's
alum DS
LT's installed. (you bring it down here we'll install them)
electric water pump
tubular K member
full length subframes (stock is harldy better than none)
MGW/ Pro 5.0
Lightweight drag wheels (bigs and skinny's)
Lotsa stuff bro.
Old Apr 8, 2010 | 06:04 PM
rygi23's Avatar
rygi23
Thx. Yup, @ MIR, great track. Pulled a few 1.69s, in the low 1.7s usually...wish I'd done 4.30s to help that, oh well.
Originally Posted by USMCrebel
intake spacer 3/8"
LCA's
alum DS
electric water pump
tubular K member
MGW/ Pro 5.0
Lotsa stuff bro.
the spacer would be the only one up my alley. I'll get one of those as soon as the the budget allows and give feedback on track #s.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
TCStangerv6
Oct 11, 2015 05:57 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Teddi
Sep 29, 2015 12:24 PM
