Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Comp Cams
Old Nov 22, 2010 | 02:54 PM
2003redmach1's Avatar
2003redmach1
Default Comp Cams
Thinkin about gettin some comp cams here pretty soon. Before I buy some though, Im just wondering what some of you guys think. What are the disadvantages compared to the advantages of getting cams for the mach 1. Hit me up and let me know some of your thoughts.
Old Nov 22, 2010 | 07:12 PM
rygi23's Avatar
rygi23
Advantage-more power. Disadvantage-a not-to-good total cost/gain ratio. Whether or not you need the additional valvetrain hardware depends upon the increase in lift and is clearly listed by each cam manufacturer. Be sure to note each cam's power range so that you're getting the power gain in the rpm range you're looking for. Also, consider 96-98 cobra intake cams as they give as much gain as a mild aftermarket cam at a fraction of the price ($150-$175), though they need about 6 degrees advance for no torque loss. Their is massive info. on these, and other cams over on M1R. One thread has a great comparison between the forementioned cams and the other ones available.
Old Nov 23, 2010 | 04:25 PM
darkstarnes's Avatar
darkstarnes
Originally Posted by rygi23
Advantage-more power. Disadvantage-a not-to-good total cost/gain ratio. Whether or not you need the additional valvetrain hardware depends upon the increase in lift and is clearly listed by each cam manufacturer. Be sure to note each cam's power range so that you're getting the power gain in the rpm range you're looking for. Also, consider 99-01 cobra intake cams as they give as much gain as a mild aftermarket cam at a fraction of the price ($150-$175), though they need about 6 degrees advance for no torque loss. Their is massive info. on these, and other cams over on M1R. One thread has a great comparison between the forementioned cams and the other ones available.
Actually consider the 96-98 cobra intake cams... they are more aggressive
Old Nov 23, 2010 | 04:47 PM
rygi23's Avatar
rygi23
thx for the correction. I owned a set of the 96-98 cams for that very reason so one could say I had a massive brainfart, lol.
Old Nov 24, 2010 | 04:24 PM
2003redmach1
well where would you go to buy cams out of a 96-98 cobra? I already checked ebay and didnt see any. Also, wut kind of gains would you get from those cams over the stock mach 1 cams?
Old Nov 25, 2010 | 02:35 PM
boduke0220's Avatar
boduke0220
go on svtp and look up a guy called NA SVT he's smart and will spec you a set of cams that wont require springs and give you more power than the comps. also get a Ported short runner intake and Longtubes to get full use of the cams. you should see 360-38-rwhp depending on the combo
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
junior04
Sep 28, 2015 10:53 AM
