Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
White smoke
Old Feb 14, 2013 | 07:38 AM
Tom V's Avatar
Tom V
Originally Posted by Sonic Mustang
After reading posts by Ford engineers I verified the following with Scott Hoag (Ford Bullitt and Mach 1 Program Manager - now owner of MRT): 5w-20 was specified for our Mach 1s and other Fords purely for CAFE (Corporate Average Fuel Economy) numbers. The 20 weight oil lets Ford eek out a couple of extra 10ths MPG in government testing. 5w-30 is the preferred weight.
If I recall correctly, the change came in 2003. Before that date, 5w-30 was spec'd for DOHC 32V 4.6 engines. Ignoring CAFE, you should use 5w-30 in your Mach 1 engine. 5w-20 certainly won't hurt it in winter temps and you probably won't be going on long 80MPH trips in February.
Thank you Sonic. I will follow your recommendation.
Old Apr 1, 2013 | 11:42 PM
4vmach1's Avatar
4vmach1
White smoke can be valve seals as well it's not just coolant. If your car is consuming more oil then usual then it's time for a compression test & a leak down right after. Pretty much if you find odd number(s) which I hope you don't, then those should be the cylinder(s) to run the leak down test. A retired Ford technician told me it's normal for our engines to burn 0.5-1 quart every 1,500-2,000 miles. It's notorious having smoke come out the exhaust during cold start, but it's not normal during driving. I hope this helps.
Old Apr 2, 2013 | 10:54 PM
Sonic Mustang's Avatar
Sonic Mustang
Banned
Boil a tea kettle full of water and put it next to your smoking exhaust pipe. If the white smoke from your tail pipe looks like steam, it's condensation. If not, it is not condensation.
b8checker
Oct 8, 2015 12:55 PM
breaking
Oct 2, 2015 01:27 PM
14gt_Track
Oct 1, 2015 02:47 PM
RCS02v6
Sep 29, 2015 01:46 PM
MacSerio
Sep 27, 2015 01:05 PM
