Massachusetts Regional Chapter Chapter President: Torch_Vert
Mass Chit-Chat
Old Jun 8, 2012 | 06:22 AM
  #411
S197GT07's Avatar
S197GT07
John, looks good!
Did you go the extra mile to make the volume buttons work?
Old Jun 8, 2012 | 08:01 AM
  #412
shad2009's Avatar
shad2009
Originally Posted by Torch_Vert
I suspect there will be some deals on pre-'13 GT500's by then. The deep pocket guys will have a tough time not trading up to the new model, with the extra power, etc
yea, i've been watching the prices of used 2010's and with the 13's out now some of the guys will be trading, and when the 14's come out, more will be traded and the price will keep falling...and since they can get them at what they own it for, might as well go for it
Old Jun 8, 2012 | 08:02 AM
  #413
shad2009's Avatar
shad2009
Originally Posted by Grim
Hooray! My window sticker posted this morning, so my car will be made by 6/15! Which means I definitely should have it before the end of the month (unless it gets selected for QC), so I should absolutely be able to make the next big cruise. Can't. Wait.
nice man...july 1st will be a huge cruise you dont wanna miss
Old Jun 8, 2012 | 10:50 AM
  #414
chaoscentral's Avatar
chaoscentral
Originally Posted by S197GT07
John, looks good!
I looked into it, I can always do that at a later time. Just not sure how I'd go about passing the wires through that other plug, I need to find another connector I can solder the extra wires to, and from there from what I saw it was simple enough you can actually connect to wires 18/19 on the shaker to control volume and next/prev track. But for now just cruise control works which I'm ok with
Old Jun 8, 2012 | 10:59 AM
  #415
Torch_Vert's Avatar
Torch_Vert
MOTORCRAFT WPT-440
Old Jun 8, 2012 | 11:12 AM
  #416
S197GT07's Avatar
S197GT07
http://www.rockauto.com/catalog/rafr...-WPT440-347095
tada
Old Jun 8, 2012 | 06:34 PM
  #417
Hill x 21's Avatar
Hill x 21
Since I'm swapping in an 03 4.6 will I need to get it tuned? And should I look into a new fuel pump?
I've read around online that some guys needed tunes, others ran it like it was.
Old Jun 8, 2012 | 09:46 PM
  #418
S197GT07's Avatar
S197GT07
Were the 96' a 4.6 or a 5.0?
I have very little knowledge of the SN95's. What size fuel pump do you have? Shouldn't be such a huge bump in power to require a new fuel pump going to the 03 motor though.
Old Jun 9, 2012 | 01:45 AM
  #419
shad2009's Avatar
shad2009
i think they are 5.0's
Old Jun 9, 2012 | 07:20 AM
  #420
chaoscentral
94-95 are 5.0's
96-98 were NPI 4.6's
99-04 were PI 4.6's
With that said I don't believe you need a different fuel setup since both PI and NPI 4.6 engines use the same 19lb injectors and fuel pump, the main difference between the years was the early SN95 used a return style fuel system and the new edges used a return-less setup, but this won't matter since the NPI fuel rails should work just fine on a PI intake. I would definitely recommend a tune either way to get the most out of the engine, but you should be able to at least drive it on the stock tune since both engines run more or less the same.
