Mid West IL, IN, IA, MI, MN, MO, OH, WI
Looking for paid work
Old Sep 23, 2009 | 02:23 PM
jeffampt's Avatar
jeffampt
Originally Posted by Ex0r
Battery is brand new. As far as the lights dimming, that could easily be caused from the car getting ready to stall out. The problem is knowing WHY it's about to stall out. I did the self check myself by taking the battery cable off the battery and the car stayed running, and it shows about 14 volts on the cluster when the car is running.
I'll take it to autozone later on and find out what they find out. Does the alternator come off the car to test it?
I would say it is not the alternator then, you should be able to do a test yourself the same way as ya did the battery.
I figured ya checked those, I was just throwing those out there I always overlook the simple things when something goes wrong with my stuff.
Old Sep 23, 2009 | 02:28 PM
Ex0r's Avatar
Ex0r
yeah, I have no idea. I've replaced MAF, IAC, had the TPS checked, ran seafoam, octane booster, and injector cleaner through it, and had it checked for vacuum leaks. No idea what the hell the problem is, but it's really annoying. Car is about to have a brand new top put on it and a new paint job, and it still runs like a POS at times.
Old Sep 27, 2009 | 06:03 PM
99GTvert's Avatar
99GTvert
is my username.
My car also would keep doing the "idle drop to near stall" thing even after I replaced the IAC on it.
What has helped reduce the issue was the idle being set a little higher. Stock was about 750rpms I think, now it's close to 1000rpms after I got a dyno tune on it.
Maybe it's time to start modding?
1TUFF302
Nov 5, 2015 04:02 PM
FivePointToTheOh
Oct 2, 2015 04:09 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
JoshyGT
Sep 7, 2015 02:04 PM
cbird1177711
Sep 3, 2015 08:43 PM
