Mustang II Section The more economy minded, compact Mustangs which were offered from 1974-1978
Battery
Old Nov 10, 2006 | 01:55 PM
The stang II's Avatar
The stang II
Default Battery
So, I got a new battery, BRAND NEW, and well it was fine. Then I left my glove box open all night one night and my car started up. But with not as much power as it did brand new. Well about a week later, last night it died on me. We got out the tester and everything seemed fine. So we charged it for about 25 minutes before I went to work and it started up but again with not as much power. I mean it hesitates not instant like a full charge battery.
Should we check for lose connections? Or what? My dad knows what we should look for, but maybe something we don't know you guys do. So give me suggestions haha.
Thank you!
Old Nov 10, 2006 | 04:02 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Battery
Hey Jake.....We created this sub section just for you, so now you can brag that you have your very own Mustang Forums section. What you need to do is to get a charger that has the ability to put out 2 amps as well as 6. Put the charger on 2 amps and let it charge all night. It needs a deep charge, and 25 minutes is not enough time to get all the cells deep charged. It's referred to as trickle charging.
Hope this helps.
Old Nov 10, 2006 | 04:50 PM
The stang II
Default RE: Battery
Haha, I like that first part. I'm cool and Special, hopefully this Section alone will bring more Mustang II owners to this forum.
But yea, I will try to charge it all night and hopefully that works. Thats helps alot, i think thats something I can do my self too! haha.
Old Nov 10, 2006 | 05:05 PM
atomsk680's Avatar
atomsk680
Default RE: Battery
chare it, start it up the next day, and cruise around for 10-15 minutes
Old Nov 10, 2006 | 05:15 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Battery
Hopefully, given time, this section will grow. In the meantime, post your questions here, and if you don't get any responses, post it in the Classic section too. Hey, a 302 is a 302 no matter which car it is in.
Old Nov 11, 2006 | 03:22 PM
The stang II
Default RE: Battery
Yea good point.
I charged it all night on 2 amps, hopefully it gets a realllyl good charge and won't ****aki out on me.
Old Nov 16, 2006 | 06:58 AM
whoafrdofdapolce's Avatar
whoafrdofdapolce
Default RE: Battery
if you turn off all accesories on the car and leave the ke in the off poshision you can unplug the ground terminal on the battery and tun a amp meeter from the ground of the battery to the cable and se how many you get. if it is more than like .6 you have a proublm
Old Nov 16, 2006 | 11:49 AM
The stang II
Default RE: Battery
We figured it out. When we moved the battery to the back of the car, we had to splice the wires so we could get enough fire. We think that something went wrong there so we are going to buy new wire thats long enough.
Old Nov 26, 2006 | 12:59 PM
Moparman87's Avatar
Moparman87
Default RE: Battery
I had a mustang II, now my uncle has it!
Old Nov 27, 2006 | 03:06 PM
The stang II
Default RE: Battery
Their pretty cool, you have any old pics of it or new?
