Leaving import for domestic, please help
Guest
Posts: n/a
RE: Leaving import for domestic, please help
A 97 GSR has 132 ft lbs torque... if you expected tons of torque out of a 4 banger then you must be crazy in the noggins. [8D]
That isn't half bad for a 1.8L that was built with PEAK HORSEPOWER IN MIND. So you blew the radiator and you're done with the car completely? How exactly does the radiator just blow up anyway? You sure a hose just didn't come off? [8D][8D] You get sick of things quick... I don't think a Mustang is your best bet if you want things to last forever (sorry guys, but it's true)
but thats cool you want a stang. I say go for it, make yourself happy. I don't think you'll find a stang and a crate motor for 7500 though.
The integra gsr makes 127 torque, the normal non vtec makes 132... You really have to drive to understand, it has two powerbands. A crappy daily driven powerband, and a kick *** racing powerband above 5500 rpm... As for the radiator, the top blew and it came spewing out. It is a common problem with integras... apparently the person that designed it thought plastic was suitable for the top of the radiator... And no, I did not expect to make a ton of torque with a four banger... But VTEC is a completely different engine than what is normal... the powerband is what I have a problem with, you truly have to drive to understand... Oh, and for you saying I get tired of things quick, I have had the car over a year now. Why the hell am I talkin' to an import guy about domestics?!?!?!
Hey 97GSR...I'm a newbie here too, but not to working on cars. lol. Thought I might add some here.
Do you work on your own cars or engines? If so, I was going to suggest one of those 331 or 347 kits for the foxbody car. If you're staying with fuel injection, you'll probably need to upgrade the fuel pump in the tank, some bigger injectors, an adjustable fuel pressure regulator, and maybe a custom computer chip to be able to utilize all the power from a 331 or 347 engine.
If that's not a feasible route to take, the 5.0 crate motor is an excellent idea, and can be run with the stock computer chip. With some minor upgrades to fuel delivery, you could hook up some nitrous for a good power shot whenever you need it. Just be sure and get a 5-speed car, you'll probably be alot happier with the performance feel of the car.
Damn, I love my 5-speed. Good luck! [sm=smiley20.gif]
Guest
Posts: n/a
Actually the non vtec b18bs in those year Integras make 127 ft lbs... you make more than that, but again it's built for peak horsepower, not torque. Out of the year i've had my Si i have driven GSRs, S2000s and the such. I wanted the GSR but I got my Si, so I have driven one. You shouldn't expect the car to have a badass bottom end, it's not built for that. However with my 111 ft lbs at 7000 rpm I can drive the car all day revving to only 5000 rpm with plenty of kick in the pants to get me up and going. If you haven't gotten used to it yet, then you probably never will.
Soo.. like I said by all means do what makes you happy, but you're not talking to just an import guy. You're talking to an all around automotive enthusiast who, by the way, is not trying to antogonize you for doing what makes you happy.
Oh and technically you're not talking to me about the mustang, you were talking to me about the Integra.
The radiator should be all aluminum, which means it shouldn't have blown out like that with proper maintenance, whoever owned it before you didn't do a good job making sure maintenance was performed apparently. I don't know, I've never heard of GSRs blowing their radiators but I don't go to Hondatech all that much.
Had I known vtec had worse bottom end than non vtec I would not have gotten it and would not be here now... I don't expect my car to have tons of torque down low, just have the powerband down low... I mean my has such a bad low end powerband due to the valve timing it feels like it is gonna bog out, I hate it. Yeah, its badass when I am in vtec but I basically have to redline every damn gear to get there... I cant imagine how bad your b16 must be about this problem[X(]
