Cold Air Intake Problem..Need help!!
Old Nov 9, 2013 | 02:48 PM
OSUjustin313's Avatar
OSUjustin313
Question Cold Air Intake Problem..Need help!!
I've had a 1999 Ford Mustang GT for about two years now and recently came across a baffling situation. As I was driving down the road at 25 mph, the car randomly shut off...happened about 3 times after that as well...then stopped. Then, picked back up and kept happening intermittently until one day, it wouldn't even kick over anymore. Took it to a Ford dealership in Columbus, Oh and they said the cold air intake was clogged and was choking the engine. Seems plausible...but I noticed (along with giving me half the wrong invoice to someone else's Taurus) that they said the cold air intake "still has problems".
First, would a clogged cold air intake cause this problem?
Secondly, what other problems would still be there (and why didn't they fix it)?
Old Nov 10, 2013 | 08:32 AM
jesse1125's Avatar
jesse1125
If your CAI has leaks it will give your Mass Air Flow sensor a lean reading. I had the same problem with my wife's 2002 vert that came with a CAI when we bought it. The CAI tube came loose and the car sputtered and died on me. All I had to do to fix it was to make sure the tube was on secure.
As far as a it being clogged, The filter should be cleaned and if you haven't cleaned it in two years it may have been clogged and starving your engine.
If it's still giving you problems then check to see if the filter was cleaned or replaced and check all the connections in the tube from the filter to the throttle body to see if there are any leaks.
Old Nov 12, 2013 | 08:59 AM
05 Mustang's Avatar
05 Mustang
welcome
If you haven't cleaned or replaced the filter in 2 years, that could be it.
heslekrants
Sep 23, 2015 04:02 PM
J.casone400
Sep 12, 2015 10:01 PM
kevsgt
Sep 9, 2015 06:20 AM
Sep 8, 2015 11:50 AM
