2000 mustang v6 can i swap an abs rear axle shaft for a non abs shaft
I bent my axle shaft. I went to the auto recyclers and they gave me a diff with abs but mine doesnt have abs. All i want to do is swap the shaft. I dont feel like waiting longer for them to order another one. Am i able to do this? I dont know if this is the right area to ask this question, im new so i dont know how to navigate this site.
Welcome to the forum.
I'm not sure on your question, but if you go back to the forum Home page, and scroll down till you see the Tech section. Start a new thread in the appropriate section and you'll get more responses there.
But I think that axle will still work for you, ABS or not.
Good luck
Good luck
It should be OK, the other way around might be a problem. The ABS version has a toothed sprocket and a sensor added, it should be easy to look at yours to see if there is anything else different.
I always put the "new" part next to the old part before I install the "new" part to make sure everything matches.
May 13, 2016 11:36 AM
