Gotta project going on
Well as I mention before my power steering pump and pressure hose decided to part ways (I mean literally) the pressure hose blew out of the fitting at pump. so tearing into this and found that rack is leaking to. Then while under car looking at leaks and trying to figure how to get rack out from crossmember . I see the sway bar links are worn out. So I decide since I'm going to have wheels off to do that I might as well replace struts that I have on shelf for it. Now all I need is some warmer weather to get all this done. whew!!
need to rest...hehehe
got the alternator replaced. That was an easy job. Started yesterday on the power steering pump and got all that off, yuk brackets plum nasty with years of leaking fluid.
currently soaking. I might just polish them while off.....hummmm.
Jan 21, 2016 01:30 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
