Oil and Oil Related Topics A place to post your oil related questions and comments
5quarts exactly for the 4.6?
Old Mar 25, 2010 | 04:57 PM
Frostbitten's Avatar
Frostbitten
Originally Posted by nascrchi
Then why does it say 5 qts in the owners manual and also in Autozones records?
On any car your supposed to fill to the full mark on the dipstick nomatter what. There is always a good bit of oil still in the engine after youve drained most of it out. Does the manual specify if the 5 quarts includes filling the oil filter? In the manual for my 2003 it says fill with 6 quarts. The 4.6 mustang oil pans are all the exact same from 1996-2004.
Old Mar 26, 2010 | 05:42 PM
mustang51js's Avatar
mustang51js
my old 97 gt i used to put in 7-8 qts before it was full
Old Mar 26, 2010 | 06:00 PM
nascrchi's Avatar
nascrchi
[QUOTE=Frostbitten;6902193]On any car your supposed to fill to the full mark on the dipstick nomatter what. There is always a good bit of oil still in the engine after youve drained most of it out. Does the manual specify if the 5 quarts includes filling the oil filter? In the manual for my 2003 it says fill with 6 quarts. The 4.6 mustang oil pans are all the exact same from 1996-2004.[/QUOTE]
you may be wrong right there. The 96-98 oil pans have an insert for the oil gauge. The oil pans for the 99-04 dont. I just did a engine swap and didnt swap the 96 oil pan to the 04 motor and my gauge has a mind of its own. When I hit the gas, either hard or soft, the needle goes from low to high. If I wot the gauge goes all the way up to high and when I let go, the gauge goes bak to low! haha weird.
Old Mar 27, 2010 | 01:33 AM
nascrchi's Avatar
nascrchi
how is that possible? I was worried about 6qts
Old Mar 27, 2010 | 02:43 AM
Snakebite64's Avatar
Snakebite64
6.1 litres here
Old Mar 27, 2010 | 07:08 AM
mustang51js
idk,i even remember going to get my oil changed and told the guy i usually put in 8, he charged me for 6 because he didnt believe me and then he put 8 in i thought i would get away without paying for the last 2, i was wrong and had to pay separate for the 2 qts since it was synthetic. This was to fill it to the max on the dip stick,and maybe it had something to do with the oil filter too but i crashed that car a week later so it doesnt matter now.
Old Mar 27, 2010 | 08:22 AM
SeanAndKate's Avatar
SeanAndKate
youll be fine with 6 qrts.
Old Feb 28, 2015 | 07:54 AM
Swann's Avatar
Swann
I have a new 2015 Mustang 5.0 and the owners manual calls for 8 quarts? The garage that changed the oil only put 6 quarts when changing the oil? Should I add the other 2??
Old Feb 28, 2015 | 10:22 AM
BlindGUYnAR's Avatar
BlindGUYnAR
what does the dipstick say? If full then the correct amount of oil is in the engine regardless of what the paperwork says.
Old thread btw. Nearly 5 years young
Old Mar 14, 2015 | 04:24 PM
Camster's Avatar
Camster
My 04 4.6 gets 6 quarts and a new filter with every change.Dipstick is aok.
