Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
first bottle
Old Mar 7, 2006 | 02:25 PM
That Guy's Avatar
That Guy
Default first bottle
I just went through my first bottle and i wanted to make sure this is supposed to happen when the bottle gets empty. I've got an NX wet 50 shot and besides an entire day of problems, including cloging the fuel line when we tapped into it, I got to make a fewruns with what N2O I had left. I could feel the jump in the first few runs, butt at the end it started to sttuter. I'm assuming that's because i'm only spraying gas and no NOS. Or is there something else wrong?
Old Mar 7, 2006 | 03:38 PM
FoxRod's Avatar
FoxRod
Default RE: first bottle
If the bottle is empty and the car started to sdputter and jump around when you tried to spray nothing went wrong except for there being no NO2. You were flooding out the engine. Because you were trying to spray the NX kit was throwing extra fuel in the system buy didn't have nitrous to mix with hense the flooding
Old Mar 7, 2006 | 04:54 PM
That Guy's Avatar
That Guy
I appreciate the info. With a guage on there could I tell how much is left?
Old Mar 7, 2006 | 05:17 PM
FoxRod's Avatar
FoxRod
Well they only have pressure gauges. The pressure gauge will tell you how much pressure in the bottle you have but not how must nitrous is left. If you have no nitrous of course the pressure will be Zero. But you are capable of having little nitrous but high pressure by heating it up. But as long as you have very little pressure or no pressure don't spray.
Old Mar 7, 2006 | 05:22 PM
CTXpitcher09's Avatar
CTXpitcher09
t
Old Mar 7, 2006 | 08:11 PM
luckythirteen13's Avatar
luckythirteen13
get a pressure gauge and a bottle warmer. the warmer will keep the pressure high and the gauge will let you know when your pressure is too low to use it
Old Mar 7, 2006 | 09:49 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
ORIGINAL: luckythirteen13
Please refer to Foxrods post above yours for a very good explanation of why what you said is wrong.
Old Mar 7, 2006 | 09:53 PM
luckythirteen13
you just explained it different
yourmom6990
3.7L V6 Technical Discussions
Oct 14, 2015 10:08 PM
Big Al's 03
Sep 15, 2015 09:05 AM
mtxplod
Aug 29, 2015 01:43 AM
kevin02
Apr 28, 2004 09:09 PM
stanger_17
Mar 19, 2004 04:20 AM
