Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Cams
Old Mar 18, 2004 | 04:09 PM
slimjim2000's Avatar
slimjim2000
Default Cams
i have heard that Cams can change the way your mustang sounds, if so could someone tell me what kind or model or whatever i need, and does it change the sound to make it louder if so i want one, thanks
Old Mar 18, 2004 | 04:38 PM
bmorrisj's Avatar
bmorrisj
Default RE: Cams
a cam would also change your car's RPM power band, it would affect your idle and stress your valvetrain parts a little more...unless you upgrade those parts too....
Old Mar 19, 2004 | 01:22 AM
yellow94gt's Avatar
yellow94gt
Default RE: Cams
If you are mildly modded go with an e-303 or a b-303 cam, they will make it sound good. If you are mid to heavily modded go with an f-303 or x-303. Also keep in mind the valve clearance with some of the harsher cams you may need to have grooves machined in your pistons to clear the valves. Take a look at tech articles in mustang traders and MM&FF
Old Mar 19, 2004 | 01:54 AM
Ian70mustang's Avatar
Ian70mustang
Default RE: Cams
If you are only trying to make your car louder than there are easier, better ways to change the sound of your motor. The change in your exhaust note is only a side effect of the cam change. Changing the cam along with other mods needed for the change, intake, headers etc. can be a great way to improve performance, and yes change your exhaust note, if thats what your looking to do.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
