nitrous
well my nitrous should be here tomorrow well today 26th zex dry kit, comes with 10lb bottle, 75 100 & 125 hp jets, purge kit, and bottle opener. 550 on ebay i couldnt pass it up. i cant wait. i will have to get the motor back in the car first.
P.S. Dont forget the pressure gauge, bottle warmer, etc. Zex makes a kit for all the accessories. They arent a must, but they help in keeping everything at right pressure for maximum horsepower gain.
im new to nitrous, do i need to change my spark plugs? also what should i set my timing? a right now its 14*, from what i heard somewere around 12*. also is ther anything else i neet to get or do befor i hit that switch?
thanks justin
thanks justin
When I had my ZEX dry kit I ran 13* with a 100 shot. That might be a little much for 92-93 octane beings i was running 100 mix. Pull about 1* for the 75 and 2* for the 100. The factory claims 2* per 50 horsepower and thats bullsh**!
Don't run nitrous w/out a bottle warmer and psi gauge. If your bottle pressure isn't atleast 900 psi don't even bother spraying it because you aint going to get the gains you want.
