Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
POWERDYNE S/C
Old May 11, 2006 | 06:20 PM
catchds's Avatar
catchds
Default POWERDYNE S/C
YO I HAVE A 97 CONVERTIBLE MUSTANG GT WITH A POWERDYNE S/C. I ALSO HAVE 4:10 GEARS, A 9.5" 300RPM STALL TORQUE CONVERTER, STAGE 2 DEIOBLO DELTA CHIP(NOT TUNED), 255 FUEL PUMP, 24LPBS INJECTORS AND A OFF ROAD H PIPE WITH 2 CHAMBER FLOWMASTERS(DUMPS) AND I NEED TO KNOW ABOUT WHAT I WILL RUN IN THE QUATER MILE AND ABOUT HOW MUCH HORSE POWER WILL I MAKE AT THE WHEELS. I HAVE ALL STOCK INTERNALS AND I HAVE 125K AND THE BLOCK AND 75K ON MY HEADS BECAUSE I REPLACED THEM BUT THEY ARE NOT P.I. SO PLEASE HELP ME AND WHAT SHOULD I DO NEXT[8D]
Old May 11, 2006 | 06:46 PM
Zoie_daGT's Avatar
Zoie_daGT
Default RE: POWERDYNE S/C
STOP YELLING!!!!! It is hard to say because there are a lot of factors involved.
How much boost?
Do you have suspension mods or tires or are they stock?
I would tune it before I even went near to a track or you may be picking up pieces of your engine. A blower needs tuned, it is critical for it to run properly. Good luck
Old May 15, 2006 | 10:53 PM
catchds's Avatar
catchds
i have stock tires and i have all stock suspenion. as a matter of fact all the rest of my car is stock. so does anyone know what kind of numbers a non pi car that is supercharged makes
Old May 15, 2006 | 10:59 PM
nanaki's Avatar
nanaki
Retired MF Moderator
280RWHP maybe (that's a generous estimate)?
Old May 16, 2006 | 12:07 AM
88stangaruu's Avatar
88stangaruu
Your suspension being stock is going to kill your E/T's. Ive learned this lesson the hard way. I put MegaBite Jrs, 90/10 struts up front with 4 cylinder springs up front, no sway bar, lowered my tires to 14psi, 1 1/2 lowering springs under the rear and dropped my E/T by almost a full second on a hot day. I was running low 13's now im low 12's. So...and next on my list is a Pro Charger, intercooled S/C...that should easily put me in mid 11's.
Soldier GT
Aug 12, 2015 03:46 PM
BlackMage
Sep 3, 2004 12:32 AM
87mustang347
Aug 31, 2004 03:41 PM
StangTangGT
Aug 13, 2004 02:57 AM
DaBOMB6082
Jan 20, 2004 05:44 PM
