Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
going to the dyno friday..... NUMBERS ARE IN!!
Old May 17, 2006 | 12:50 AM
  #21
BlackSVTsnake302's Avatar
BlackSVTsnake302
Default RE: going to the dyno friday.....
478 to the wheels, thats my guess
Old May 17, 2006 | 04:55 PM
  #22
88stangaruu's Avatar
88stangaruu
Is all this on a stock bottom end? Just curious....im getting ready to make something like that...im very curious to see if my engine is going to hold up.
Old May 17, 2006 | 07:30 PM
  #23
luckythirteen13's Avatar
luckythirteen13
block, crank, cam, rods, pistons, oil pump, etc......all stock
Old May 17, 2006 | 07:58 PM
  #24
88stangaruu
it holding up pretty good? Im in the same boat. Except i have an F cam.
Old May 17, 2006 | 09:19 PM
  #25
luckythirteen13
np yet
Old May 19, 2006 | 07:48 PM
  #26
luckythirteen13
well guys friday is here and im back from the dyno
nitrous_bob had the best guess with 405rwhp but only cause of a technicality. the numbers as you can see are 407rwhp and 417rwtq. picked up 4hp and 17tq. but as you can see the afr is way off and the hp numbers shows something screwy happening at 5000rpms but because the afr was off the chart we dont know what happened. more then likely a rich spike.
the cars last run, i had -34% fuel entered in the pms which means i was only running 66% of the fuel the stock computer was programmed to run at wot. my firt that was "WFT!!!!" with a sc running that low of fuel and still off the chart rich. dyno tuner said it sounds like the maf might be screwing me but hes not sure how the pms works so i called rick anderson while i was still at the shop. the very first thing he said when i described the problem was bad maf. said thats it for sure and since i did by the maf used, i guess im buying a new one in the next couple days. but on the plus side, look at it this way...407rwhp and 417rwtq from the stock block, cam and all internals, on 10.2psi of boost, with an afr off the chart rich and only 27* total timing (should be more like 32-35* with the methanol) through an AOD transmission. not bad i suppose
also, all the runs were back to back. i made 6 runs in less then an hour so there was no time for the intake to cool down. we iced it once but it was on the 3rd run and thats not on this graph.
Galactic
Apr 29, 2019 02:56 PM
articman
Jun 21, 2018 11:45 PM
heslekrants
Sep 23, 2015 04:02 PM
Sep 23, 2015 01:28 PM
The01Cav
North East
Sep 5, 2015 03:39 PM
