kenne bell boost
a few questions for ya guys,could i run a kenne belle 6 psi supercharger on a 94 gt stock motor if i run 30 lbs injectors or do i need 42's? 75 maf and 70 tb and a 190 fuel pump or do i need 255? can i run this without causing any engine trouble like a piston going through the block?
6 lbs of boost should be fine on a stock engine if its tuned right, ud be okay with 30lb at only 6psi. You would get a much larger bang for u buck by doin a head/cam/intake swap tho...
ya i know i would, but i just not sure which way to go yet, and i can not get the supercharger out of my head, plus i wondered what size fuel pump and injectors i would need to run at about 6 or 9 psi if it wont destroy my engine.
jwog666
Dec 27, 2021 08:09 PM
