if you have an msd (and you should..the stock spark will be weak and erratic at high rpm's) you can hook up a timing control. it's basically a **** that you dial your timing.
i just bump manually
msd 6a is fine.....6al is not really necessary cuz you can't override the stock limiter anyways.
