Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
max boost
Old May 24, 2006 | 12:02 AM
mlax's Avatar
mlax
Default max boost
When I rebuilg my block this winter what is the max boost that I can run. I have a vortech now running 9#'s. The block will be completely forged pistons thru crank. The S/C is the sq-2
Old May 24, 2006 | 01:54 AM
luckythirteen13's Avatar
luckythirteen13
Default RE: max boost
there is no actual boost limit. its the hp limit you have to watch out for. if your still running the stock block, your limited on the hp you can make. they can break anywhere from 400rwhp to 550rwhp and higher then that is a guarrenty it will split
if its not the stock block, run as much as you want
Old May 24, 2006 | 12:09 PM
nanaki's Avatar
nanaki
Retired MF Moderator
yeah. your block will probably be able to handle more boost than your blower can give. you just have to worry about snapping an axel or your tranny going bye bye before your built bottom end.
Old May 24, 2006 | 08:27 PM
mlax's Avatar
mlax
Yeah I was more concerned with what the max limit of the blower would be. I plan to do the botom end and the trans next winter. Maybe a viper-spec 6 speed. I think about 600hp to the tires will be enough for me.
Old May 24, 2006 | 08:34 PM
nanaki's Avatar
nanaki
it's never enough. you'll be saying 800 will be good next year.
Old May 25, 2006 | 03:54 PM
mlax's Avatar
mlax
So true!
jwog666
Dec 27, 2021 08:09 PM
TCStangerv6
Oct 11, 2015 05:57 PM
angeljoelv
SVT Forums
Sep 10, 2015 09:12 PM
Sep 8, 2015 11:50 AM
RWHEELS
Sep 5, 2015 03:42 PM
