Vortech Supercharger
I'm buying for vortech v-2 off a guy and he said it will fit a 01-04, I have a 2000 gt, wont it fit it too? On Vortech's site they make a supercharger for the 00-04. I'm thinking it will fit mine because there really isnt any difference between the years right? Also what lbs injectors should I get? It is non intercooled and I'm only going to run at about 6psi for now
RE: Vortech Supercharger
all 96-04 GT vortech head units are universal for 96-04. you will need a mounting bracket if the blower was for a mid 00-04 and you have an early 00 or 99. same goes with 96-98. the brackets (with belt and everything) from vortech is $299 and $279 from superchargersonline.com
Another difference on the kits was the MAF/IAT sensor. On the later kits you needed a new IAT because in the 01-04 cars the IAT was located inside the MAF.
If you have a seperate IAT you are fine. You will need to relocate the IAT after the supercharger.
If you do not have a seperate IAT you will need to remove the wires for the IAT from the MAF connector and install a seperate IAT.
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
2004, 2007, difference, gt, iat, install, installing, mustang, sensor, supercharger, superchargers, vortech, vortex
