Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
boost
Old Jun 23, 2006 | 03:02 AM
dhuskers_11's Avatar
dhuskers_11
Default boost
what is the most boost you could have on stock v6 internals and be completely safe 7, 9, 11?
Old Jun 23, 2006 | 09:27 AM
nanaki's Avatar
nanaki
Retired MF Moderator
Default RE: boost
there's plenty of people in the v6 section running 11
Old Jun 23, 2006 | 10:01 AM
03YellowPony's Avatar
03YellowPony
Default RE: boost
ORIGINAL: nanaki
Not me. Not on stock internals. I wouldn't go over 9 with stock internals..but that's me playing it safe.
Old Jun 23, 2006 | 11:46 AM
nanaki's Avatar
nanaki
Default RE: boost
well you suck then! people say 8psi max on a stock GT, but i've been running 10psi for over a year!
it more depends on the power you're putting down than the psi. i could have run 12psi as long as i was at or under 400RWHP with a safe tune.
Old Jun 23, 2006 | 05:54 PM
FoxRod's Avatar
FoxRod
Default RE: boost
It also depends on what condition the motor is in, how much you push your car, how competent the driver is, what other supporting mods you have done. There is a lot of factors as to why and what people do. If your motor is in really good shape, i.e. no oil leaks, no idling problems, and no other problems then you should be able to run more boost safely. But on the other hand if you have oil leaks, prepare for them to get a lot worse the more boost you add. When it all comes down to it, what condition is you motor and trans in, how much do you push your car, what do you feel safe with?
Old Jun 23, 2006 | 06:46 PM
dhuskers_11
Default RE: boost
its a 99 with only 49k on it and i treat my car very good
Old Jun 23, 2006 | 07:27 PM
FoxRod's Avatar
FoxRod
Default RE: boost
Any oil leaks? How's your tranny? Have you ever had any over-heating problems? How many gaskets (within the entire motor) have you changed? Do you race often? Do you ever just get on your car for fun, and how often?
These are all questions you need to take into account.
If you don't any oil leaks, have a "strong" tranny, never had over-heating probs, have changed a few gaskets or at least not affraid to have to, you don't race but maybe 1 or 2 times a week, and you just get on your car for fun occasionally and not everytime you turn the car on, Then feel secure in running a higher boost.
What is the compression ratio on the V6's? That will help in knowing what is a good psi number. For every 5 lbs of boost, it's 1 point of compression.
Like mine I have 8:1 compression stock. I add 10 lbs. of boost, now I have 10:1 compression.
Also, is the block a 2 or 4 bolt main?
jwog666
Dec 27, 2021 08:09 PM
TCStangerv6
Oct 11, 2015 05:57 PM
Oct 7, 2015 07:02 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
angeljoelv
SVT Forums
Sep 10, 2015 09:12 PM
