Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
lowered compression
Old Jul 9, 2006 | 02:58 PM
psi pony's Avatar
psi pony
Default lowered compression
what is the easiest/most efficient way to lower compression, i want to add some N20 to the setup eventually, thanx
Old Jul 10, 2006 | 05:51 PM
luckythirteen13's Avatar
luckythirteen13
Default RE: lowered compression
swap pistons.
why lower compression, stock compression is fine for running a 100shot. i wouldnt run more then that tho
Old Jul 10, 2006 | 05:58 PM
Vash the Stampede's Avatar
Vash the Stampede
ORIGINAL: luckythirteen13
swap pistons.
not when your already supercharged...
cuz the compression is already shot up from that.
iam sorta glad i went the nitrous only way out. because i don't have to worry about acheiving full boost. its power on demand always. threw every gear.
Old Jul 11, 2006 | 04:08 PM
psi pony's Avatar
psi pony
yeah, its definitely supercharged. haha. its running about 14-16 lbs. but i have yet to push it hard and wont until i get the cooler on, if then. everyone says piston swap is the way to go. whats your input vash?
Old Jul 11, 2006 | 10:07 PM
luckythirteen13
dont know what i was thinking, missed the sc.
if the block is stock, you cant running any n2o regardless of compression. 14psi should be making enough power to put you into the block splitting range. if the car isnt dyno tuned i wouldnt even get on the gas. and with the intercooler, youll just make more power
lincolnshibuya
Jul 5, 2020 03:05 AM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Oct 3, 2015 06:23 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
NYstang
Sep 30, 2015 09:56 PM
