Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Maximum Boost
Old Jul 15, 2006 | 02:08 AM
pedal2themedal's Avatar
pedal2themedal
Default Maximum Boost
What is the maximum psi boost you can run with a twin turbo system and still use pump gas?
Old Jul 15, 2006 | 02:31 AM
deezelnut's Avatar
deezelnut
I ♥ Acer
Default RE: Maximum Boost
the max i would run with pump gas would be 14 PSI. but it also depends on the tune. you are safe with 10 PSI
Old Jul 15, 2006 | 02:37 AM
pedal2themedal
How cheap is good race gas? Im talking like the gas you would use to run 15-22 psi. What octane do you have to have?
Old Jul 15, 2006 | 03:00 AM
nanaki's Avatar
nanaki
Retired MF Moderator
get a boost cooler and run 50/50 water/methanol. that'll boost your octane a good bit.
Old Jul 15, 2006 | 09:50 AM
99saleen351r's Avatar
99saleen351r
ORIGINAL: nanaki
+1.... can run 20 pounds then
Old Jul 15, 2006 | 11:14 AM
tripsevn7's Avatar
tripsevn7
Moderating with Angels
a stock 4.6 seeing 20 psi>???????????????? crazy
Old Jul 15, 2006 | 01:19 PM
pedal2themedal
no, hell no, not stock, fully built, im not that dumb
Old Jul 15, 2006 | 01:34 PM
tripsevn7's Avatar
tripsevn7
gotcha, didnt see where you had posted the built engine part.
Old Jul 15, 2006 | 03:41 PM
FoxRod's Avatar
FoxRod
As much as you can before you start detonating. It's hard to tell. Are you going to have a meth/alcohol injection, intercooler, nitrous anything like that. The cooler you make the intake charge the more PSI you can run.
jwog666
Dec 27, 2021 08:09 PM
robcy
Suspension
Oct 27, 2015 11:14 PM
TCStangerv6
Oct 11, 2015 05:57 PM
Oct 7, 2015 07:02 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
