9psi boost question
9lbs will be fine as long as you have a good tune. Most supercharger companies don't recommend over 8lbs of boost, but 10lbs is pretty much the safest "understood" boost pressure for a stock bottom end. I've seen alot of people running 12+ lbs without any problems, really it has more to do with your tune and how high you wind up. T&J recommends not exceeding 6k rpm if your running 10+ on a stock engine, so I don't see where 9 would be a problem.
Boost has very little to do with how the engine will stay in tact. I don't like seeing a lot of people say "Will 10 lbs. kill my motor? If I run X amount of boost, will it blow?" It's not about the boost at all, really. It's the power you're making at X amount of boost. If your rods, pistons, crank, whatever it may be.. can't hold the power, then it's over for the motor.. or it just won't last a very long time. There's also other things that play factors in a good "reliable stock block big horsepower" motor too. Like, tuning, etc. Think about it.
jwog666
Dec 27, 2021 08:09 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
