Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
How much...
Old Aug 14, 2006 | 07:49 PM
91LXStang2727's Avatar
91LXStang2727
Default How much...
Generally how much does a tune cost for a s/c?
Old Aug 14, 2006 | 07:54 PM
luckythirteen13's Avatar
luckythirteen13
Default RE: How much...
if you buy a base kit that comes with an fmu and boost retard timing box you can technically get away without a tune (assuming your running a 6psi kit) but its not advised to run an fmu or the boost timing retard because a dyno tune and chip is done for your car specifically. typically with the chip and tune your looking at $700ish. can be more or less depending on the shop.
Old Aug 14, 2006 | 09:32 PM
janine's Avatar
janine
I was charged $500 for the flash tune after they installed my charger. It took seven pulls www.mustangmagic.com
simple_john
Mar 21, 2008 01:59 PM
tungsten07
Mar 16, 2008 04:32 PM
Sentinala
Jan 2, 2008 04:38 PM
CobraStangGT16
Dec 4, 2007 08:54 PM
