Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
prochamber problem
Old Jun 30, 2004 | 03:19 AM
nd4spd86's Avatar
nd4spd86
Default prochamber problem
ok after a couple hours of fighting to get the h-pipe on I start the car up and I have one mean leak comming from the drivers side exhaust manifold where it bolts to the h-pipe. I tried unbolting it and moving it around a bit and that helped but its still quite the leak. has anyone else had this problem? any help would be appreciated. btw '00 GT vert
Old Jun 30, 2004 | 11:54 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: prochamber problem
Often times on that side the studs coming from the manifolds aren't threaded all the way down, so when you tighten up the h-pipe to the manifold you think your tight because the nut is bottoming out where the threads end, but in reality its no tight all the way. Get some new fully threaded studs from napa or something and replace the stockers.
Old Jun 30, 2004 | 03:29 PM
nd4spd86's Avatar
nd4spd86
how would i go about getting the old studs/ bolts out they seem to be pretty well stuck up in there...
Old Jun 30, 2004 | 03:32 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
double nut them and back em out
Old Jun 30, 2004 | 03:35 PM
nd4spd86's Avatar
nd4spd86
thanks
2007CalSpec
Dec 13, 2020 11:42 AM
Seanam
Oct 4, 2015 10:15 AM
marc954
Sep 25, 2015 06:48 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
