Help..
I got some high temp RTV sealant for my left side exhaust manifold for installing the H pipe and it says it drys in 1 hr. and fully cures in 24 hrs! How long do you think I need to wait to drive the car??
ORIGINAL: mdvaldosta
That RTV is gonna last all of 30 seconds no matter how long you let it cure. Why aren't you using a gasket?
Here are the directions:
Installation tips:
1. For best results, apply a small amount of anti-seize on each of the fastener locations.
2. loosely fit your H-Pipe together
3. Re-Install oxygen sencors in H-pipe
4. Apply a small bead of Permatex black high temp sencor safe RTV on the drivers side exhaust manifold "bell mouth" (on the H-pipe side of the joint)
5. Slide H-pipe into position at the exhaust manifolds.
6. Start the nuts on the exhaust manifold studs (do not tighten yet)
7. Slide the cat back tail pipes onto the balled ends of the H-pipe
8. Loosely start four nut and bolt joints at this joint
9. Using your hands or sure grip clamp, press the "H" slip joint together enough to allow the joint interfaces at the "H" slip joint together enough to allow the joint interfaces at the exhaust manifolds to line up. support the H-pipe vertically at the "H" in approximate vehicle location
10. Tighten right hand exhaust flange nuts
11. Tighten left hand exhaust flange nuts
12. Plug in oxygen sensors.
Installation tips:
Demoneyejin
21
Oct 23, 2006 07:17 PM
