Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
better 1/4 time
Old Sep 26, 2006 | 11:54 PM
wills98cobra's Avatar
wills98cobra
Default better 1/4 time
say i was in low gear reved up to 2K or so and wanted to spray 100 shot of nitrous right off the line with some good drag slicks on my car and everything else is stock would this damage the engine or tranny doing it this way? or should i pick up some speed first then hit it? i was wanting to lower et times and 0to60 so i was thinking about doing this
Old Sep 27, 2006 | 01:02 AM
africkanV6's Avatar
africkanV6
Default RE: better 1/4 time
dont do it off the line. do it in second and 3rd gear. off the line your gonna put too much stress on your drivetrain. i think its worth the patience. if u push it in second your 0-60 should drop. not by much tho
Old Sep 27, 2006 | 01:16 AM
FullAuto's Avatar
FullAuto
I don't have as much problem with doing it off the line as I do using it below 3000rpm. If it were on a window switch, I'd leave on it.
Old Sep 27, 2006 | 01:38 AM
africkanV6's Avatar
africkanV6
well he has a cobra so his drivetrain should be a bit stronger. but i figure **** lol you get through 1st fast enough as it is. so jus go and spray in ur power gears. pull hard through 2nd and 3rd and your 1/4 should drop by a good amount
Old Sep 27, 2006 | 07:03 PM
luckythirteen13's Avatar
luckythirteen13
put a window switch on it. that way its not spraying right off the line but really close to it
Old Sep 27, 2006 | 08:22 PM
03sonicgt's Avatar
03sonicgt
Just flip your switch when you get past 3k, thats what I do.
mungodrums
Oct 7, 2015 04:01 AM
96stang3.8
Sep 10, 2015 06:42 AM
Sep 8, 2015 11:50 AM
zachary1988
Sep 4, 2015 03:04 PM
