Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
how much??
Old Oct 24, 2006 | 01:59 AM
Justastockmustang's Avatar
Justastockmustang
Default RE: how much??
When I increased my boost I used the water/meth to prevent detonation on pump gas without pulling timing. I was able to go 3 psi over what I could run without it. Using it at boost would not be a optional thing, it has to be used every time. It actually makes the mixture richer for a little safety magin. I could have gone much further but my shortblock is at its limit.
It would be interesting to use nitrous that way because there would be no pump needed but while the nitrous would do a great job of cooling the charge, I don't know how much you could raise the boost without going dangerously lean.
Old Oct 24, 2006 | 04:00 AM
SSKiller's Avatar
SSKiller
ORIGINAL: Justastockmustang
Mine didn't raise boost psi. But I did make 40 more RWHP.
Old Oct 24, 2006 | 10:38 AM
Justastockmustang
The goal of the original poster and mine as well was to raise the boost. The use of the meth was to do this without detonation. He was also asking what HP gain from the meth there might be.
I'm sure the nitrous would make power. Surely it cools the charge. Adding nitrous with no fuel while increasing boost sounds very dangerous.
There is additional HP in meth too, but to see much of that would require retuning. Adding the meth without specific retuning still allows the boost increase without detonation with a comfort margin in the mixture. Seems like a safer route to me, especially for those not experienced with nitrous.
ORIGINAL: SSKiller
Old Oct 24, 2006 | 12:43 PM
newb2000GT's Avatar
newb2000GT
I think the point here is that both meth and N2O will cool the mixture allowing either more timing or safety to increase boost while runnning the same octane. The difference is that N2O will also add more power on top of being able to have more freedom with the tune. Boost and nitrous don't blow motors, going lean or making too much power does. Both tools allow you to gain more power in similar ways but methanol's added HP is negligible, it's the cooling function that net's the more tunable power while nitrous cools and adds power itself.
Old Oct 24, 2006 | 07:17 PM
Justastockmustang
No, the point is that water/meth will cool the charge without leaning it out.
Using a dry shot of nitrous will cool the charge, but will also lean out the mixture.
That is a big difference when when the goal is to raise the boost. The added HP of nitrous is great, but not if it goes lean and blows.
Now if someone wants to explain how leaning out the mixture and adding boost is just as safe, I'm listening. (in the context of the above example)
ORIGINAL: newb2000GT
Old Oct 24, 2006 | 07:31 PM
blown91lx's Avatar
blown91lx
I am running the vortech A trim with the methonal injection. I also run a 100 dry shot of NOS. Let me say wow what a difference the NOS makes. She is one nasty BItch. I suggest start at a 75 shot for a couple runs and then pull the plugs to make sure your not running to lean. Mine runs a 100 shot with no problems.
Old Oct 24, 2006 | 07:59 PM
Justastockmustang
OK guys, help me understand, I not familiar enough with nitrous.
hydro45f is already running 8psi non-intercooled. Assuming his motor is built, he wants to run 15psi. The meth would let him do this without detonating. He could have it tuned to lean it out while on meth for more HP.
What would he have to do to SAFELY use a dry nitrous shot to accomplish this?
ORIGINAL: hydro45f
i have an o4 mach1 with a vortech non intercooled, i am running 8lbs of boost. I just recently put on water-methanol injection and i was wondering how much boost i can run with only the waster-meth and a good tune? Also, how much power do you think the water meth will add after its tuned?
Old Oct 26, 2006 | 01:14 PM
Sic5OohSC's Avatar
Sic5OohSC
As in anything you do.....A Good tune
you have your car tuned to the meth as you would N2O. I wouldnt feel safe shooting a 100 shot Dry with my SC but if it works sure. My plan was to do a FMIC and spray the Intercooler with N2O when racing. Could you make a wrap bar around the charge pipe and spray N2O on that and make it work as well? anyone know
