Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Nitrous Guys
Old Nov 2, 2006 | 02:38 PM
99SlvrStang's Avatar
99SlvrStang
Default Nitrous Guys
Hey guys i was just wondering how many passes you could get out of one bottle of nitrous before filling it up? Also i heard the nitrous tune "kills" your n/a tune, is that true?
Old Nov 2, 2006 | 03:13 PM
samseed101's Avatar
samseed101
Default RE: Nitrous Guys
What size is the bottle? How big are the jets? How long as the solenoids open?
Asking how many passes you can get out of a bottle of nitrous is like asking how many drinks of water you can take from a bottle until it's empty. How big is the bottle? How big are the "gulps?" How long does each one last?
Old Nov 2, 2006 | 03:59 PM
Frebius's Avatar
Frebius
I have a 10lb bottle at 80 shot and it lasts me about 6-8 runs down the 1/4
Old Nov 2, 2006 | 05:41 PM
Zoie_daGT's Avatar
Zoie_daGT
I normally get about 8 runs out of a 10lb. bottle @100 shot. That is spraying from the beginning of third to the end. I do fill up regularly so I always have some go fast juice in the bottle when I need it.
Old Nov 3, 2006 | 02:24 AM
99SlvrStang
how about the tune??
Old Nov 4, 2006 | 01:52 AM
97 5.0L's Avatar
97 5.0L
the tune should retard your timing a bit for the nitrous so yes running on a nitrous tune will make you run a bit slower N/A. But not much. If you dont retard your timing for the nitrous it could hurt your engine.
Old Nov 4, 2006 | 03:14 AM
luckythirteen13's Avatar
luckythirteen13
and you have to run colder plugs with n2o which will hurt your hp when n/a
Old Nov 4, 2006 | 06:59 PM
nitrous_bob's Avatar
nitrous_bob
i don't use colder plugs , i'm jetted for 80 and get about 10 full passes. newer cars can benefit from a flipswitch , that way you don't have to be a slug NA
foxbodies just can use a msd dial and dial the timing whenever needed from your seat.
i spray right out of the hole, keep my bottle hot at all times, (cold bottle waste a lot of nitrous)
i usually fill up when i have 3 lbs left.
Old Nov 8, 2006 | 07:06 PM
04GTMustangRob's Avatar
04GTMustangRob
the rule of thumb is that with 100 shot jets you will use 1 lb of nitrous for every 10 seconds you are spraying. I can get around 7 passes before my pressure starts to drop.
RWHEELS
Sep 5, 2015 03:42 PM
SilverStallion05
Sep 5, 2015 10:48 AM
Emblazoned
Sep 3, 2015 10:45 PM
