Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Boost Levels
Old Nov 19, 2006 | 04:02 AM
kev2369's Avatar
kev2369
Default Boost Levels
I was wondering what kind of boost you guys build throughout your RPM range. Mine only makes 9lb when it is screaming. Makes 4-7 up to like 4 grand and 9 at about 5 grand. I was wondering if that was about right, or if i'm loosing air somewhere. It also stays on vacuum going down the road, about 20lbs, which is normal right? Any info would help alot. Thanks
Old Nov 19, 2006 | 05:16 AM
99roushgt's Avatar
99roushgt
Default RE: Boost Levels
yes man thats perfectly normal you shouldnt boost under easy acceleration and we really dont start making any boost until 3000rpms anyways your fine as long as you dont see your boost build up to say 9 and then dwindle away in the higher rpms there should be no boost leak
Old Nov 20, 2006 | 01:18 AM
kev2369's Avatar
kev2369
Alright. Well that's what i thought. Was just wondering if when it starting gaining if it should just peg over or if it was a gradual thing. Thanks
jwog666
Dec 27, 2021 08:09 PM
TCStangerv6
Oct 11, 2015 05:57 PM
guitarman376
Sep 30, 2015 05:54 PM
Sep 8, 2015 11:50 AM
Sep 1, 2015 08:16 PM
