Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Nitrous setup.
Old Nov 20, 2006 | 01:16 AM
fiad06's Avatar
fiad06
Default Nitrous setup.
If someone can, i would apreciate it if they can make a list of what parts i am going to need to get nitrous installed....from the bottle to the purge...someone please give me a full list.
Old Nov 20, 2006 | 12:01 PM
Zoie_daGT's Avatar
Zoie_daGT
Default RE: Nitrous setup.
I will explain it some w/ a wet kit. You will need:
- bottle
- hoses
- jet kit
- fuel line and fitting to the Schrader valve
- bottle warmer
- purge(not neccessary but looks nice)
- nitrous
- wiring
- arm switch and WOT switch
- tuning chip
- dyno tune(Tuning is critical w/ nitrous)
- possible gauges( not neccessary but will help out)
i. nitrous pressure
ii. fuel pressure
This is what you need. Not all of it is essential but that would be a full setup. Good luck
Old Nov 20, 2006 | 05:42 PM
fiad06's Avatar
fiad06
What about a window switch is it the same as a wot switch?
Old Nov 20, 2006 | 06:00 PM
04GTMustangRob's Avatar
04GTMustangRob
no, the WOT is a wide open throttle switch. with it the nitrous activates at WOT.
the window switch creates an RPM window for which the nitrous activates. I have mine set for 3000 to 6500 RPM.
Old Nov 20, 2006 | 06:20 PM
fiad06's Avatar
fiad06
ORIGINAL: 04GTMustangRob
Which one is better?
whats ur full N20 setup?
Old Nov 20, 2006 | 06:26 PM
04GTMustangRob
I have both along with an arming switch. mine won't spray unless it is between 3000 and 6000 RPM, only I have the peddle to the floor and it's turned on.
my full setup is:
NX Plate kit - model # 20946-10
NX GenX2 safety kit
NX Fuel Rail Adaptor - model # 16183
Cup holder arming switch from www.americanmuscle.com
MSD window switch - model # 8969
Air/Fuel ratio guage
Fuel pressure guage
SCT Xcal2 Tuner with custom dyno tune
I think that is it, if I think of anything else I will let you know.
PullTab
Oct 30, 2015 08:46 AM
Lethaldosage423
Oct 19, 2015 12:12 AM
Sandmanbjj
Aug 21, 2015 12:38 PM
dangthatsfast
Aug 6, 2015 09:46 PM
