nitrous install question
does anyone have a pic of where you run your fuel line on a fox body mustang. mine didn't come with any instructions so i have no idea where the fuel line goes. does it come off the fuel rail somewhere> and what does the shrader valve look like cause i'm not sure if i have one of those either.
look at the fuel rail on the passenger side. towards the front you will see two hard lines split from the rail and go down the front/side of the motor. one is the supply line the other is the return. the schrader valve will be on the supply line towards the top of the motor. it may have a black cap over it, it may not. you have to unscrew it and put the n2o fuel line in its place
ORIGINAL: 1fastzook
here you go.
[IMG]local://upfiles/29615/C82466EC676242B09B1FF4A168D5CBB7.jpg[/IMG]
here you go.
[IMG]local://upfiles/29615/363E4E70FDB24F0A9E6B08D6245D25A5.jpg[/IMG]
Shifty Magoo
Aug 25, 2015 03:08 PM
