Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Snow Performance
Old Dec 6, 2006 | 02:34 AM
jerjan's Avatar
jerjan
Default RE: Snow Performance
If you just add meth and don't retune you will not gain anywhere near the HP you could. The meth will boost your octane considerably, this allows for lots of timing advance so ya gotta retune to get the hidden ponies! Meth works there ain't no doubt about it. Anyone who says it doesn't has probably been drinkin it!
[IMG]local://upfiles/54591/A9ADBDFA6C20442C9F0BE0F535148D2E.jpg[/IMG]
Old Dec 6, 2006 | 04:14 PM
luckythirteen13's Avatar
luckythirteen13
ORIGINAL: Frostbitten
I am just going with an intercooler though cause I heard that meth does nothing...
you heard completely wrong. nanaki picked up about 45rwhp from his kit. i picked up about 50rwhp from my kit. last time i checked a 45-50rwhp was more then nothing
Old Dec 6, 2006 | 05:15 PM
lizzyfan's Avatar
lizzyfan
Underboss
I probably won't tune it anymore aggressive than it is. Like I said, it's just for peace of mind as I'm running high C/R
Old Dec 6, 2006 | 05:17 PM
lizzyfan's Avatar
lizzyfan
Underboss
I want to mount pump inside fenderwall, anyone else do this? Do not want to relocate battery
Old Dec 6, 2006 | 05:40 PM
7upedition's Avatar
7upedition
^ You obviously should do your homework, and +1 on not giving advice if you have no clue... meth injection is intended for use with boost and the proper tune is required to reep the benefits...
Old Dec 6, 2006 | 06:30 PM
nanaki's Avatar
nanaki
Retired MF Moderator
just tap your existing reservoir.
Old Dec 6, 2006 | 07:13 PM
Zoie_daGT's Avatar
Zoie_daGT
ORIGINAL: nanaki
you can put the pump anywhere. Alot of people like to hide it in the fenderwell. I am just going with an intercooler though cause I heard that meth does nothing...
i didn't even fully read that. tell me why i went from 360RWHP to 410RWHP after my methanol kit running basic wiper fluid. dyno proven on my own car. i guess that didn't really happen?
Srry, man. You were just dreaming. You dont even have a blown GT. You are going to wake up in about 30 min. and realize that you are dumping your money into a VTEC 2 JZ Stage III RPG(jk no offense to import guys). Sorry but it is true.
Anyways, Meth injection works.
Old Dec 6, 2006 | 08:54 PM
lizzyfan's Avatar
lizzyfan
Underboss
ORIGINAL: lizzyfan
Anyone???
Old Dec 6, 2006 | 09:27 PM
nanaki's Avatar
nanaki
ORIGINAL: lizzyfan
ORIGINAL: lizzyfan
Anyone???
my actual pump and safe injection unit is mounted in the fenderwell on the driver side.
Old Dec 9, 2006 | 09:56 PM
jerjan's Avatar
jerjan
Meth can be injected on a normally aspirated motor also. You don't gotta be superchared to reap the benefits from it. Meth will effectively raise 91 octane pump gas to an octane over 110! That will definitely help any one with a high compression engine. As stated before it also cools the air intake charge which allows the fuel to atomize more completely. All these benefits equal performance. Meth is good for any engine anywhere anytime. check out snowperformance.com
jwog666
Dec 27, 2021 08:09 PM
Dokilar
15
Oct 16, 2015 08:13 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
