Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Next bypass question
Old Jan 1, 2007 | 06:05 AM
bransdaman78's Avatar
bransdaman78
I ♥ Acer
Default Next bypass question
Ok now that I know I have to have one, which bypass/ bov is the loudest?
Old Jan 2, 2007 | 02:20 PM
luckythirteen13's Avatar
luckythirteen13
Default RE: Next bypass question
bypass valves are silent because the air is dumped back into the air system after the maf. if you want to hear it, youll need a bov. if you want a bov youll need to run a blow through maf and the bov has to be before it. procharger is the only one that runs a blow through maf setup. you can run a bov on a draw through maf setup but every time you shift, you will dump metered air into the atmosphere which will cause a rich spike in your afr which isnt good for the motor and will cost you hp.
Old Jan 2, 2007 | 04:14 PM
bransdaman78
I ♥ Acer
so can I by a blow through maf and set it up for another blower - or is procharger the only company that makes blow throughs... I have always been told that bov were not as loud on s/c setups, but I was hoping maybe something new had come out that was a little bit closer to how the turbo bov sounds
Old Jan 17, 2007 | 03:39 AM
FoxGT's Avatar
FoxGT
It doesn't just do the spikes when you shift, running a bov in a draw through setup will cause the car to run poorly anytime your car is under partial throttle. The valve is venting at all times other than wot.
There is nothing different between the setups as far as the meters go. To switch to a blow through setup all you have to do is get piping & plumb the meter to be located after the supercharger
The bov is the same sound on both providing both are running the same psi, same valve, & a similar intake setup.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
