Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Difference in SQ and S Trim.
Old Jan 4, 2007 | 11:55 PM
V8Cody's Avatar
V8Cody
Default Difference in SQ and S Trim.
Sorry for the pretty stupid question, but like the title says, what is the main difference?
SQ is the queit gear drive right? So is the S-Trim the normal loud as hell or what?
Thanks!
Old Jan 5, 2007 | 02:55 AM
bransdaman78's Avatar
bransdaman78
I ♥ Acer
Default RE: Difference in SQ and S Trim.
well thats its porbly correct, all I really know about is the difference between the v1- and v2
Old Jan 5, 2007 | 04:53 AM
Shawn02GT's Avatar
Shawn02GT
both the v1s and v2sq are the "s" trim which flow 1000 cfm, the difference is that the v1 has the straight cut gears which is louder than the sq. they both boost to 20 psi, up to 680 hp. There is no just "s" trim model. hope this helps
Old Jan 6, 2007 | 12:08 AM
2000GT4.6's Avatar
2000GT4.6
The S has a different impeller design than the SQ, and is louder. The SQ is still fairly loud at idle.
I was told by the shop that the SQ will make SLIGHTLY (very small difference) more power than the S. The SQ is the newer design.
Old Jan 6, 2007 | 03:46 AM
bransdaman78
I ♥ Acer
yep, I believe the v-2 also has a higher step up, more comparable to ATI
Dokilar
15
Oct 16, 2015 08:13 PM
breaking
Oct 2, 2015 01:27 PM
UrS4
Sep 30, 2015 10:13 AM
mrappe
Sep 26, 2015 10:16 AM
