Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
procharger help
Old Feb 10, 2007 | 01:40 PM
rvoss5's Avatar
rvoss5
Default procharger help
ok so i had some trouble with a procharger (p1sc) that i bought from a guy on here. the compressor wheel would get stuck. well we took the wheel casing off and it looked like the compressor wheel needed to be pushed down a ways. we got it to just below the lip on the housing. for those who have opened one up, how far below that lip should we go? it also has a bolt and a spacer that i suppose is used to press the wheel down. between the spacer is there supposed to be a washer or anything? or should we keep pushing it down till the shoulders on the spacer touch the metal rod that sticks up in the middle of the compressor wheel? right now we are probably 1 mm or less under the lip. there is approximately 1 mm left inbetween the spacer and the metal shaft. thanks for your help
articman
Jun 21, 2018 11:45 PM
Granatelli Sales
Mar 21, 2016 06:16 PM
Dragonus18
Sep 9, 2015 01:21 AM
Black_GT_02
Aug 20, 2015 01:26 PM
RedStangGT2000
May 15, 2004 05:55 PM
