Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
window switch
Old Feb 16, 2007 | 12:45 AM
nitrous_fed_03gt's Avatar
nitrous_fed_03gt
Default window switch
i have a fuel pressure switch on my nitrous set up, but do you guys really think a window switch is a must on an automatic? i dont even activate the nitrous until i get in second gear as it is, but i guess sometimes its a pain to have to flick it manually, but i dont really see any other advantage of having it on just a hundred shot. its not like im going to break my tires loose in the higher rpms of any other gear besides 1st.
Old Feb 16, 2007 | 01:12 AM
bransdaman78's Avatar
bransdaman78
I ♥ Acer
Default RE: window switch
yes I would say so, i dont know what it shifts at, but if the gear hung or something it might be a good idea, but you also dont want to spray too low - thats just as dangerous
Old Feb 16, 2007 | 03:52 AM
luckythirteen13's Avatar
luckythirteen13
so you just flip a switch when you shift into 2nd that activates the n2o??
i would run a window switch if i was you. and get some suspension work so you can spray in first.
Old Feb 16, 2007 | 12:15 PM
04GTMustangRob's Avatar
04GTMustangRob
a window switch is always a good idea. I have one on my set-up so that I don't spray too low and if I happen to miss a shift, I don't ping my rev limiter and damage my engine.
Old Feb 17, 2007 | 12:51 AM
nitrous_fed_03gt
what do u have ur rpms set at? 3000-6000
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
PaulH2
20
Jan 31, 2016 09:48 AM
guitarman376
Sep 30, 2015 05:54 PM
DreadPirateRoberts
Sep 26, 2015 02:11 PM
