Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
[Deleted]
Old Nov 2, 2004 | 08:49 PM
Deleted User's Avatar
Deleted User
I ♥ Acer
Default [Deleted]
[Deleted by Admins]
Old Nov 2, 2004 | 11:19 PM
Deleted User
I ♥ Acer
Default [Deleted]
[Deleted by Admins]
Old Nov 2, 2004 | 11:23 PM
code3GT's Avatar
code3GT
Mustang Nazi
Default RE: Nitrous for 01' GT
That just means you can adjust your jet sizes for whatever shot you want to run.
Old Nov 3, 2004 | 02:32 AM
GT00_80's Avatar
GT00_80
Most kits come with almost everything you need, but you will have to fabricate a few things. The only exception I know of is the ZEX kit. I have it and it is a complete kit with more than you need (just in case). It also has the easiest install of all I've done. The ZEX kit comes with jets for 75 100 and 125 jets. They only take a few seconds to change.
Old Nov 3, 2004 | 07:55 PM
Deleted User
I ♥ Acer
Default [Deleted]
[Deleted by Admins]
Old Nov 3, 2004 | 07:57 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
I don't know why you would have to fab anything... its just a bottle with some hoses and stuff to mount with screws. Thats a nice looking kit by the way, at a great price. NX is the best too. You'll wanna invest in a bottle pressure gauge as well thought, thats a must - same thing with a bottle warmer and a purge valve if you wanna be consistant.
Old Nov 3, 2004 | 11:19 PM
GT00_80's Avatar
GT00_80
On most kits Ive seen, you have to fabricate a bracket for the throttle switch(the one that engages the nitros at WOT). But, ZEX's kit uses the voltage curve of the throttle positioning sensor to determine when you floor it. Much more acurate and reliable!!
Old Nov 4, 2004 | 03:43 AM
94Cbra's Avatar
94Cbra
NX is not necessaraly the best kit! Please do research before you buy! If you research products you will see that Holley's NOS systems have the strongest lines and highest flowing Nossels along with the most complete and safest kits. Most people think NX kits are better because they rate their HP at the rear wheels. Im a trained salesman and this is one of the best marketing techniques Ive ever seen used. So many people fall for it without giving a proper look at the competition. All NX does to acheive their RWHP numbers is to up the HP at the crank! No **** huh? Thats why you have to be so careful when looking into NX kits, you have no idea what kind of crank numbers they are throwing out so you could do some serious engine damage if your not careful! You can make any N20 system rated for RWHP. Also the Holley N20 systems comes with every safty feature the NX kit does PLUS a Fuel pressure safety switch. That means if for some reason you fuel pressure doesnt go up high enough, the system will not engage so you wont make a lean spray and create engine crippling detonation. Once again, do some comparisons between NX, NOS, and Zex before you buy. Call each manufacturer and ask them questions. A good question to ask them is "As a customer why should I go with your kit over NOS? Why should I go with your kit over Zex?" and vise versa for other brands. Like I said, Im a trained salesman and we always said "you cant sell a salesman", with that being said Holley impressed me much more than the other brands.
Edit: That kit does come with everything needed and, it would be a great kit to have. The price is also very reasonable. Dont think I dont like NX or Zex systems. Both are very good systems. Just make sure you throughly investigate each brand before making a final decision.
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
DtRockstar1
Mustang Videos
Sep 27, 2015 07:46 PM
Camster
Sep 10, 2015 11:18 AM
