zex window switch
Hey guys, Im in the process of wrapping up the install of the zex 82015 drykit and the 82025 window switch. From looking through old posts I found the TPS outputwire is the green wire coming from the TPS and one of the wires goes to the tach output which is the tan/orange wirewithyellow stripe from the distributor.When looking at the plug on the distributor its the 2nd wire from the bottom.With the car idling the window switch numbers jump erradically and the windowswitch is set from 3000-5000 rpms but the active switch is alreadypulsating at idle. I tried calling the zex hotlineand the guy was no help. He suggested sending the switch back before hearing my problem. Any ideas from anyone using the zex windowswitch?Am I using the correct wires?What does your window switch displayread at idle with the arming switch on?Thanks!!
DreadPirateRoberts
Sep 26, 2015 02:11 PM
